Booking.com Booking.com
العودة   منتديات بن سات > القسم الفضائي العام > اهم مواضيع وشروحات الدريم بوكس
اهم مواضيع وشروحات الدريم بوكس خاص بأجهزر الدريم بوكس
إضافة رد
أدوات الموضوع انواع عرض الموضوع
  رقم المشاركة : 1
قديم 04-17-2009, 07:32 PM
دريم 500
دريم 500 غير متواجد حالياً
دريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond reputeدريم 500 has a reputation beyond repute
Arrow softcam.tv برنامج تحميل مفاتيح
SoftCam.Tv Keys Downloader v9a - b :
Announcement About Hac ksat Key DownloaderIn some forums there is a rumour about hac ksat key downloader. About it get dreambox keys. All of you know this forum and that product. Our group not need any dreambox passwords. And this plugin not work as a trojan.
If you know us please help us to beat this rumour in forums you know.
How you will understand this program as legitimate program:
"first u open it hac ksatkeys.so with wordpad and read it command u can see all wget commands"
Password button only for people who forgot their dreambox password. "For not to deal with tuxbox commander" only a detail. It only download passwd file to dreambox for solve your problem. It has no use for hac king dreambox. Only for user friendly helper file. Hac ksat key "Downloader" Not "Upload" (Not Send) any information from your dreambox.
regardsHac kSat.Org Team
ALL OLD VERSION DIED USE V9a ONLYdownloaded all time updated keys
mgcamd keys (SoftCam.Key AutoRoll.Key tps.au files)cccam keys (SoftCam.Key AutoRoll.Key tps.au files)cccam keys (constant.cw file)
evocamd keys (Keylist.txt and Autoupdate.Key files)
newcamd keys ( rsakeylist and keylist files)newcamd keys ( constantcw key file)
gbox keys (nagra key file)gbox keys (softcam.cfg key file)
camd3 keys (camd3.keys file)clear all keys button and passwd reset button
Whats new: In old versions had a key deletion problem when *** page not working. It's fixed...
Now If *** page not working camd selection screen will not appear.
if this screen not appear you can understand wep page problem happened.
With this fix your keys will not be deleted.
Also Because of the domain name change new links for key download are added
Hint from Future Releases: Menu and Channel Lock Reset will be add.
download this file and send in /tmp and use addons manuel on remote control for install (only dreambox 500 and 70x0)
DOWNLOAD
download to enigma2 for dm7025 and dm800
enjoy
ESKİ SÜRÜMLER KEY İNDİRMEZ V9a KULLANMANIZ GEREKİRpluginimizin artık Türkçe sürümünü de çıkardık
eski versiyondaki *** sayfası çalışmadığında indirilmeye çalışılan keylerin
silinmesi sorunu giderildi.
Şimdi *** sitesi çalışmadığı zamanlarda key indirme menüsü ekrana gelmeyecektir
böylelikle hem key indirme butonlarını seçemeyecek hemde seçemediğiniz zamanlarda
*** sitesinin çalışmadığını anlayabileceksiniz
tabi keylerinizde zarar görmeyecek sıfırlanmayacaktır
ve yeni key indirme adresleri eklenmiştir, eski adresler artık çalışmamaktadır
bu sebeple versiyon 9 dan önceki sürümlerde key güncelleme işlemini yapamazsınız
v9b sürümünde menu ve çocuk kilidi şifresini unutanlar için şifre resetleme fonksiyonu eklenmiştir Dreambox'da mgcamd cccam camd3 gbox newcamd evocamd keyleri güncelleme
mgcamd keys (SoftCam.Key AutoRoll.Key tps.au key dosyaları)cccam keys (SoftCam.Key AutoRoll.Key tps.au key dosyaları)cccam keys (constant.cw key dosyası)
evocamd keys (Keylist.txt and Autoupdate.Key key dosyaları)
newcamd keys ( rsakeylist and keylist key dosyaları)newcamd keys ( constantcw key dosyası)
gbox keys (nagra key dosyası)gbox keys (softcam.cfg key dosyası)
camd3 keys (camd3.keys dosyası)
****** ile indirilen tüm keylerin silinmesi için bir buton ve dreambox şifresini unutanlar için passwd reset butonu
artık hac ksat softcam seçtiğinizde hangi camdi kullanıyorsanız o camdin key dosyalarını seçerek indirebilirsiniz. keyler indikten 2 sn sonra pencere plugins kısmına otomatik olarak geçer bu şekilde keylerin inip inmediğini de anlamış olursunuz.
(newcamd dosyaları /var/keys/scce içine indirilmektedir newcamd kullanıyorsanız zaten oraya direk iner kullanmıyorsanız scce klasörünüz yoksa o dosyalar inmez dosyayı hac ksat addons kullananlar direk dreamden hac ksat addonstan indirip kurabilirler
kullanmıyan arkadaşlar aşağıdaki dosyayı indirip açmadan dreambox ın /tmp klasörü altına atıp addonstan manuel kısmından kumanda ile kurabilirler
İNDİRdm800 ve dm7025 için enigma2 ****** indir
(bazı keylerde eksiklik olabilir bunu zamanla sizler kullandıkça belirtirseniz geliştirmeye devam edebiliriz)
******te ve key işlemelerinde emeği geçen tüm hac ksat teame
(Hack Sat.Org Team @alimansur @asus @coscos @ozzymanborn @eniss @uyducu) arkadaşlara sonsuz teşekkürler.
saygılar
SoftCam.Tv SoftCam.Key download SoftWare for Windows PC (thnx @tonytr)
Bilgisayar üzerinden dvbs kartlarla yayın izleyen arkadaşlarımız için softcam.key, v_dcw_sharing.ini ve gbox nagra key dosyası indirir
SoftCam.Tv DCW ***Sharing Status Page SoftWare
Bu basit program ile hangi kanalların açık olduğunu değişen keylerden görebilirsiniz
Şifreleri (DVBFile softcam'ı) vPlug'un formatına çevirmek.
Elimizde bir dvb kart- bir gösterici - ve plugin var (vPlug) fakat şifreler yok. Kanala basıyoruz Fakat normalde çözüldüğünü bildiğimiz şifreli kanal açılmıyor. AU yapan kanallar bile açılmıyor niye mi çünkü gerekli keyleri programımıza tanıtmamız gerekiyor.
We have a dvb card, a player, and a plugin (vPlug) but no keys. We wait on a crypted channel but it's not open but we now actually that channel is cryptable. AU Channels are not working too. Because we need actual keys and we make compatible for vPlug.
Öncelikle DVBFile softcam indir ile güncel softcam'ı alıyoruz.
First of all we download latest softcam with DVBFile softcam indir.
softcamın yeri önemli değil.
place of softcam is not important.
Şimdi DVB oynatıcımızı açıp plugins bölümünden vPlug'u seçip show monitor'ü tıklıyoruz.
Now we open our dvb player and in plugins select vPlug > show monitor.
Sonra (1) Mavi Prizmaya tıklayıp editör'ü açıyoruz.
Then we open editor with clicking (1) blue prism.
(2)Üç noktaya tıklıyoruz. Açılan pencerede softcamın olduğu dizini seçiyoruz ve aç'a basıyoruz.
(2)We click (...) this window we browse to the our softcam file. And we click open.
(3)Sonunda convert'e basıyoruz ve softcamımız kendisini vPlug'un kullanabileceği dosyaya v_keys.db'ye yazıyor. Artık çözülebilen kanalları izleyebiliriz.
(3)Finaly we click convert and our softcam.key write itself as v_keys.db and we can now use our keys and we can enjoy our watching.
التوقيع
رد مع اقتباس
  رقم المشاركة : 2
قديم 04-26-2009, 12:41 AM
i3isking
عضو
i3isking غير متواجد حالياً
i3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond reputei3isking has a reputation beyond repute
افتراضي رد: softcam.tv برنامج تحميل مفاتيح
thank you
التوقيع.
رد مع اقتباس
  رقم المشاركة : 3
قديم 05-01-2009, 09:41 PM
azar3203
عضو
azar3203 غير متواجد حالياً
azar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond reputeazar3203 has a reputation beyond repute
thank you
التوقيع.
رد مع اقتباس
  رقم المشاركة : 4
قديم 05-01-2009, 10:16 PM
azar3203
عضو
thank you
التوقيع.
رد مع اقتباس
  رقم المشاركة : 5
قديم 05-21-2009, 04:52 AM
سمارا
عضو
سمارا غير متواجد حالياً
سمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond reputeسمارا has a reputation beyond repute
يعطيك العافية والى الامام اخى العزيز
التوقيع.
رد مع اقتباس
  رقم المشاركة : 6
قديم 05-21-2009, 08:42 PM
فراس الشبح
عضو
فراس الشبح غير متواجد حالياً
فراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond reputeفراس الشبح has a reputation beyond repute
ممنون جدااااااااااااااااااااا
التوقيع.
رد مع اقتباس
  رقم المشاركة : 7
قديم 06-10-2009, 07:19 AM
boyofcasa
عضو
boyofcasa غير متواجد حالياً
boyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond reputeboyofcasa has a reputation beyond repute
thank's
التوقيع.
رد مع اقتباس
  رقم المشاركة : 8
قديم 06-14-2009, 12:42 AM
mahhar
عضو
mahhar غير متواجد حالياً
mahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond reputemahhar has a reputation beyond repute
THANKSSSSSSSSSSSSSSS>>>>>>>>>2U
التوقيع.
رد مع اقتباس
  رقم المشاركة : 9
قديم 06-16-2009, 08:05 PM
أنوروجدى
عضو
أنوروجدى غير متواجد حالياً
أنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond reputeأنوروجدى has a reputation beyond repute
الف الف شكرررررررررررررررررررررررررر
التوقيع.
رد مع اقتباس
  رقم المشاركة : 10
قديم 06-17-2009, 01:05 AM
brian_242
عضو
brian_242 غير متواجد حالياً
brian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond reputebrian_242 has a reputation beyond repute
thhhhhhhaaaaaaaaaanks
التوقيع.
رد مع اقتباس
إضافة رد
مواقع النشر (المفضلة)
الكلمات الدليلية (Tags)
مفاتيح, تحميل, برنامج, softcamtv
أدوات الموضوع
انواع عرض الموضوع
ضوابط المشاركة
لا تستطيع إضافة مواضيع جديدة
لا تستطيع الرد على المواضيع
لا تستطيع إرفاق ملفات
لا تستطيع تعديل مشاركاتك
كود [IMG]متاحة
كود HTML معطلة
المواضيع المتشابهه
الموضوع كاتب الموضوع المنتدى مشاركات آخر مشاركة
أقوى برنامج لمشاهدة القنوات العالمية و العربية | LiveEventsGui V2 أبو عادل القنوات الفضائية 1 07-12-2014 05:47 AM
الساعة الآن 01:56 PM
منتديات بن سات
a.d - i.s.s.w
منتج الاعلانات العشوائي بدعم من منتديات
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
تصميم/ابن تواما
